[Gdal-dev] PG-Driver supporting no views?
Fri Apr 23 09:21:13 EDT 2004
Tyler Mitchell wrote:
> Is this just because there isn't an entry in geometry_columns?
> Tyler
Tyler,
The OGR PG driver isn't restricted to stuff that appears in GEOMETRY_COLUMNS.
I use the following magical query to get a list of tables that can be treated
as layers:
                          "DECLARE mycursor CURSOR for "
                          "SELECT relname FROM pg_class "
                          "WHERE relkind = 'r' AND relname !~ '^pg'" );
I think I copied that from somewhere else originally.  The GEOMETRY_COLUMNS
is currently only used to lookup SRID values.
So I think the problem is that my query only idenfies proper tables, not views.
If anyone can suggest an appropriate change to pick up queries too, I can update
it more easily.
Best regards,
