[Gdal-dev] GDAL in delphi .. reading pixel values (Esri grids)
jk nz jk_nzd at hotmail.com
Mon Apr 26 01:48:01 EDT 2004
Has anyone tried using GDAL from the Borland Delphi language?
I have been mostly sucessful in doing so, but having problems reading pixel
values from an esri grid..
Does anyone have sample code of reading pixels? C is ok .. I have seen
sample of reading blocks but that wasnt quite what I wanted ...
I do not know how to extract the pixel values as I dont know how they are
laid out in memory .. is it a 2d grid, or a 1d grid?
eg is it laid out in memory as
row1 [px1][px2][px3][...]
row2 (possible some memory gap in between rows) [px10][px11][...]
or as row1 [px1][px2][...] (row2, no gap in memory, next pixel is at address
pxN+ sizeof(px)) [px10][...]
It appears I have to use pointer arithmetic to index the block, ie pixelN :=
block[index] works fine if it is a 1d grid in memory, but its not so easy if
its a 2d grid, as the operator block[x,y] is not valid in delphi
So I'm trying to figure out what happens at the end of a row? is the first
element of the next row located in the next memory address or ...?
Any help appreciated
Regards
JK.
Here is my code: - everything appears to work, apart from reading individual
pixel values.
            for i := 0 to nYBlocks - 1 do // i = Y block index
              for j := 0 to nYBlocks - 1 do // j = X block index
              begin
                GDALReadBlock(RasterBand, j, i, pafScanline);
                // compute which part of the block is valid for partial
blocks
                if(i * nBlockYSize > nY) then
                  nYValid := nY - i * nBlockYSize
                else
                  nYValid := nBlockYSize;
                if(j * nBlockXSize > nX) then
                  nXValid := nX - j * nBlockXSize
                else
                  nXValid := nBlockXSize;
                doubleptr := @pafScanline;
                for k := 0 to nYValid - 1 do // k = Y cell index
                  for l := 0 to nXValid - 1 do // l = X cell index
                  begin
                    inc(doubleptr);
                    cell := doubleptr^;
                    // debugging stuff, did we get an ok value or not?
                    if cell > 0 then
                      ShowMessage(FloatToStr(cell));
                  end; // for l, for k
              end; // for j, for i
_________________________________________________________________
Need more speed? Get Xtra JetStream  @ http://xtra.co.nz/jetstream
