[Gdal-dev] Re: Transforming shapefiles from euref89 to ed50
Jakob Simon-Gaarde/Trapsoft Inc Jakobs at trapezesoftware.com
Mon Apr 26 05:45:19 EDT 2004
Thanks for your insight Frank.
Unfortunately I haven't come further in my stroggle of transforming those
layers (many hours of frustration). Maybe the problem is my restricted
knowlegde about  the whole issue. I was wondering if anyone would like to
take the challenge and try transforming this
http://80.160.199.114/test/utm_ed50_z32n.zip to this
http://80.160.199.114/test/utm_euref89_z32n.zip.
Med venlig hilsen / Best regards
Jakob Simon-Gaarde
Trapeze Software Europe A/S
Tlf. 87 44 16 00
|         |           Frank Warmerdam      |
|         |           <warmerdam at pobox.com>|
|         |           Sent by:             |
|         |           gdal-dev-admin at remote|
|         |           sensing.org          |
|         |           21-04-2004 15:41     |
|         |           Please respond to    |
|         |           gdal-dev             |
  |       To:       gdal-dev at remotesensing.org        |
  |       cc:        |
  |       Subject:  Re: [Gdal-dev] Re: Transforming shapefiles from euref89 to ed50                                              |
Jakob Simon-Gaarde/Trapsoft Inc wrote:
>>>>t=osr.CoordinateTransformation(sr_euref,sr_ed50)
>>>>t.TransformPoint(560728.35341,6079776.68768)
> (560731.3203323764, 6079908.6868730783, 0.0)
> should have been
> (560728.35341 ; 6079776.68768) -> (560808.942 ; 6079982.529)
> Any ideas??
Jakob,
I'm not sure why there is the difference.  But note that the WKT
you are using does not include any information about datum shifts,
so I would presume only an ellipsoid change is taking place.
> By the way isn't there a collection of wkt-files somewhere that are
> garanteed correct?
There is (was?) a sample translation of the EPSG database
translated into WKT made available when the OGC Coordinate
Transformation Specification was released.  However, it is far
from guaranteed correct.  Datum shift parameters are particularly
problematic.  For instance, for NAD27 to NAD83 translation there
are many available known methods including various simple
approximations (TOWGS84 style) that can be applied in some
location area, and shift file based conversions.  My point is, that
knowing the datum you have doesn't mean there is one unique way to
convert to WGS84.  There are many, and that is a big problem in
doing EPSG to WKT conversions.
I believe the GML CRS spec avoids this issue by not allowing
specification of shift parameters with the datum ... just offload
to somewhere else.
> by the way the unnamed tool is ESRI MapObjects based.
I'm pretty sure the ESRI projection engine keeps track of a
set of datum shift information which it looks up based on the
datum name, but which isn't explicit in the WKT.  The
OGRSpatialReference does *not* do that lookup.  If the TOWGS84
parameters aren't in the WKT then they are not applied.   I imagine
that is the difference.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
