[Gdal-dev] Gdal and pyramid files
Wed Apr 28 08:31:56 EDT 2004
Tim Sutton wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi again
> I have been comparing the performance of (gdal based) qgis against  * ahem *
> arcmap using the Nasa blue marble visible earth dataset (two tiffs totalling
> roughly 2.8gig). In general arcmap rendering is faster, especially when
> zoomed out so that most or all of the dataset is in view.
> I found the following message in the archives:
> http://remotesensing.org/pipermail/gdal-dev/2003-August/000948.html
> And was wondering if the use of rrd files is automatic in the gdal tiff
> driver, or if there is something special I need to "activate"?
Tim,
GDAL does not use ArcMap .rrd files (really Erdas Imagine files) except
when the base file is an Erdas Imagine file.
> On a similar note, if I create overviews using the gdaladdo utilitiy, does
> gdal automatically look for and use the associated .ovr file?
If GDAL supports building the overviews for a given format, then it will
auto-detect the .ovr file when reading and use for suitable resolution
requests.
> Lastly, is it possible call gdaladdo programmatically?
Certainly. The core method is the BuildOverviews() method on the GDALDataset
class.  You can look in gdal/apps/gdaladdo.cpp to see how it is called in C++.
There is a corresponding GDALBuildOverviews() C function as well.
Best regards,
