[Gdal-dev] OGR PG bugfix
Wed Apr 28 08:46:15 EDT 2004
Markus Neteler wrote:
> Frank,
> a strange parse error appears currently with PG connections.
> After quite some time I found it:
> diff -u -r1.22 ogrpgdatasource.cpp
> --- ogrpgdatasource.cpp	23 Apr 2004 15:10:10 -0000	1.22
> +++ ogrpgdatasource.cpp	28 Apr 2004 06:21:35 -0000
> @@ -273,7 +273,7 @@
>          hResult = PQexec(hPGConn,
>                           "DECLARE mycursor CURSOR for "
>                           "SELECT relname FROM pg_class "
> -                         "WHERE (relkind in ('r','v') AND relname !~ '^pg'" );
> +                         "WHERE (relkind in ('r','v') AND relname !~ '^pg')" );
>      if( hResult && PQresultStatus(hResult) == PGRES_COMMAND_OK )
Markus,
Yikes!  My mistake. I have committed the fix to CVS.
Best regards,
