[Gdal-dev] win32 binary gdal distribution
Matt Wilkie matt.wilkie at gov.yk.ca
Wed Apr 28 12:58:21 EDT 2004
Ben Discoe wrote:
>>> (2) run every time you open a shell on Windows... far better to
>>> simply put the GDAL bin dir on your path, a one-time operation.
>> 2) If you CALL the batchfile from autoexec.bat you don't need to
>> run it for every shell.
> That's an interesting idea; i hadn't thought of that DOS legacy thing
>  for years.  Can you actually set environment variables there, which
> are then set through the whole OS?
> ..for the purposes of installing any apps (e.g. VTP) which use GDAL,
> it has to be added to the path anyway - a batch file run from a shell
> won't do it, since it can't affect the system path.
just found this utility for setting persistent system variables from the
commandline:
http://www.microsoft.com/windows2000/techinfo/reskit/tools/existing/setx-o.asp
It's a free download but probably not redistributable (I didn't bother
my poor befuddled mind with the license agreement). Although the
download is 600k the actual exe is only 24k.
cheers,
-matt
