[Gdal-dev] ERMapper .ers ?
Brent Fraser bfraser at geoanalytic.com
Thu Apr 29 16:17:10 EDT 2004
Frank,
ERMapper has a free C library available (different from the ECW SDK).  It
allows reading of ".ers" and ".alg" files.  From my little dabbling that
I've done with it, the C api should fit into the GDAL architecture without
too much pain.  The doc is fairly poor, but there are a couple of example
apps included with SDK.
http://www.ermapper.com/sdks/default.aspx#erm
Brent Fraser
----- Original Message -----
To: <gdal-dev at remotesensing.org>
Sent: Thursday, April 29, 2004 12:46 PM
Subject: Re: [Gdal-dev] ERMapper .ers ?
> Ben Discoe wrote:
> > I've been asked about the ERMapper .ers format... could GDAL read/write
it?
> > It seems to be an open format, in that ERMapper generally encourages
people
> > to use their format.  It is a raster format, i think?
> Ben,
>  From a few samples I have seen I gather the .ers file is basically an
ascii
> header describing an external raster file which can be in any number of
formats.
> I presume there is some raw raster format for files generated within
ERMapper.
> I think that in some cases the .ers file is also an algorithm description
of
> how to generate a raster from other files.
> However, I'm not really very sure of any of this.
> If folks want to scare up some examples datasets (not too huge I hope) I
> could look at implementing some degree of support.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
