[Gdal-dev] Problems with writing RasterIO on WinXP
J.Krueger kruegerj at gmx.de
Sun Aug 1 15:26:01 EDT 2004
Hello,
While toying around with gdal today I encountered a strange problem:
I was familarizing myself with image calculations and basic io and
therefore wrote a simple 'fusion' program that worked fine when running
on a Win2k machine at work. But when I tried it on my WinXP Pro machine
at home it suddenly started crashing as soon as it encountered the
following instruction:
-cut-
fusionBand->RasterIO( GF_Write, 0, j, xsize, 1,
             fusionBuffer, xsize, 1, GDT_Float32,
             0, 0 );
-cut-
I tried the binary I compiled on the Win2k, but neither that nor
binaries compiled on the WinXP machine itself work. I also tried the 1.2
stable release of the library and the latest CVS (30th May) - without
any differences. At work I'm a simple user with restricted rights, while
on the XP machine I have admin rights, so it can't be a problem with the
permissions.
Is this a known problem? I attached the source, so you may check it for
yourself.
Jochen
#include <iostream>
#include <stdlib.h>
#include <gdal_priv.h>
#ifndef test
  #define test
#endif
using namespace std;
// global variable definitions
int errorvalue;
GDALDataset *highresDataset, *lowresDataset, *fusionDataset;
GDALDriver *outputDriver;
// function definitions
void rotatingCursor ();
float *analyseBuffer(float *hrBuffer, float *lrBuffer, int bsize);
int main(int argc, char *argv[])
    cout << "SimpleFusion Demo" << endl << endl;
    // read command line arguments
    const char* highresFilename = argv[1];
    const char* lowresFilename  = argv[2];
    const char* fusionFilename  = argv[3];
    // load highres dataset
    GDALAllRegister();
    #ifdef test
    cout << "loading highres dataset" << endl;
    #endif
    highresDataset = (GDALDataset *) GDALOpen( highresFilename, GA_ReadOnly );
    if( highresDataset == NULL ) {
        cout << endl << "can't load highresDataset" << endl;
        return 1;
    // load lowres dataset
    #ifdef test
    cout << "loading lowres dataset" << endl;
    #endif
    lowresDataset = (GDALDataset *) GDALOpen( lowresFilename, GA_ReadOnly );
    if( lowresDataset == NULL ) {
        cout << endl << "can't load lowresDataset" << endl;
        return 1;
    // get basic stats
    int maxbands = lowresDataset->GetRasterCount();
    int xsize = lowresDataset->GetRasterXSize();
    int ysize = lowresDataset->GetRasterYSize();
    #ifdef test
    cout << endl << "image size: " << xsize << "x" << ysize << "x" << maxbands << endl;
    #endif
    // create fusion dataset
    remove(fusionFilename);
    #ifdef test
    cout << endl << "creating fusion dataset" << endl;
    #endif
    char* outputFormat = "HFA";
    outputDriver = GetGDALDriverManager()->GetDriverByName(outputFormat);
    fusionDataset = outputDriver->CreateCopy( fusionFilename, lowresDataset, FALSE,
                                    NULL, NULL, NULL );
    // load bands
    GDALRasterBand *highresBand, *lowresBand, *fusionBand;
    float *highresBuffer, *lowresBuffer, *fusionBuffer;
    #ifdef test
    cout << endl << "loading highres band" << endl;
    #endif
    highresBand = highresDataset->GetRasterBand( 1 );
    // defining bandsize
    xsize = highresBand->GetXSize();
    ysize = highresBand->GetYSize();
    // creating buffers
    int bufferSize = xsize * 1;
    highresBuffer = (float *) CPLMalloc(sizeof(float)*bufferSize);
    lowresBuffer  = (float *) CPLMalloc(sizeof(float)*bufferSize);
    fusionBuffer  = (float *) CPLMalloc(sizeof(float)*bufferSize);
    // looping through lowres bands
    int i=1;
    while (i < (maxbands+1)) {
        cout << endl << "loading lowres band " << i << endl;
        lowresBand = lowresDataset->GetRasterBand( i );
        fusionBand = fusionDataset->GetRasterBand( i );
        // looping through image lines
        cout << "Processing...  ";
        int j=0;
        while (j < (ysize)) {
            // load highres line
            highresBand->RasterIO( GF_Read, 0, j, xsize, 1,
                              highresBuffer, xsize, 1, GDT_Float32,
                              0, 0 );
            // load lowres line
            lowresBand->RasterIO( GF_Read, 0, j, xsize, 1,
                              lowresBuffer, xsize, 1, GDT_Float32,
                              0, 0 );
            // process image
            fusionBuffer = analyseBuffer(highresBuffer,lowresBuffer,bufferSize);
            rotatingCursor();
            // save fusion line
                              0, 0 );
            j += 1;
        cout << "\bdone!" << endl;
        i += 1;
float *analyseBuffer(float *hrBuffer, float *lrBuffer, int bsize) {
    float *fuBuffer;
    fuBuffer = (float *) CPLMalloc(sizeof(float)*bsize);
    int i=1;
    while (i <= bsize) {
        fuBuffer[i]=(hrBuffer[i] + hrBuffer[i] + lrBuffer[i]) / 3;
        i += 1;
    return fuBuffer;
int rotatingCursorSelector = 0;
void rotatingCursor () {
    char *symbols = "|/-\\|/-\\";
    if (rotatingCursorSelector == 8) rotatingCursorSelector = 0;
    cout << "\b" << symbols[(rotatingCursorSelector++)];
