R: [Gdal-dev] GetSpatialRef() returns a NULL pointer.
Sanges Michele Michele.Sanges at otomelara.it
Tue Aug 3 03:27:17 EDT 2004
> -----Messaggio originale-----
> Da: Tyler Mitchell [mailto:tylermitchell at shaw.ca]
> Inviato: lunedì 2 agosto 2004 16.25
> A: gdal-dev at xserve.flids.com; Sanges Michele
> Oggetto: Re: [Gdal-dev] GetSpatialRef() returns a NULL pointer.
> Michele, do you have a projection file with your shapefile (i.e.
> airports.prj)?  SpatialRef is the spatial reference system
> point.  Is it the
> projection info itself you are looking for?  It didn't sound
> like it from
> your email.  I think you want to get at the geometries, not a
> spatialref.
> Tyler
Tyler,
I want extract the GEOGRAPHIC (or UTM) COORDINATES from some vector map files (ESRI shapefile), which do not have the relative prj file.
I get the geometries in order to draw the different shapes (point, line, polyline, polygon...) embedded in any shapefile, but how can I get the geographic coordinates? I'm newbie in OGR, and I thought that it was made by means the SpatialRef class.
Thanks a lot.
Michele
