[Gdal-dev] Problems compiling GDAL with MrSID 4.x DSDK
Ryan Moore rmmoore80 at yahoo.com
Thu Aug 5 10:46:12 EDT 2004
Ahh, our SIDs are RGB.  Any idea of an ETA on this
fix?  Our ortho layers are using TIF's and those are a
pain.
I played with it a little and got it to a point where
it says that it can not find 'lti_bufferData.h' but
after searching my entire hard drive, the file does
not seem to exist.  I even redownloaded the DSDK's
(both vc6 and vc7).
Here is the section from my nmake.opt file referencing
MrSID files:
# Uncomment the following for MrSID support.
# You will likely require /MD and /EHsc in OPTFLAGS.
MRSID_DIR =	c:\mrsid
#MRSID_INCLUDE = -I$(MRSID_DIR)\include
#MRSID_LIB =	/LIBPATH:$(MRSID_DIR)\lib \
#		MrSIDDecode_md.lib lt_xTrans_md.lib advapi32.lib
user32.lib
# Uncomment, if you have DSDK version 3.1.x
#MRSID_FLAGS =	-DMRSID_DSDK_VERSION_31
# Uncomment, if you have DSDK version 3.2.x
#MRSID_FLAGS =	-DMRSID_DSDK_VERSION_32
# Following suitable for the MrSID DSDK version 4.0.x.
MRSID_INCLUDE = -I$(MRSID_DIR)\include\base \
		-I$(MRSID_DIR)\include\support \
		-I$(MRSID_DIR)\include\metadata \
		-I$(MRSID_DIR)\include\mrsid_readers \
MRSID_LIB =	/LIBPATH:$(MRSID_DIR)\lib\Release_md \
		lti_dsdk.lib advapi32.lib user32.lib
MRSID_FLAGS =	-DMRSID_DSDK_VERSION_40
Ryan M. Moore
--- Brent Fraser <bfraser at geoanalytic.com> wrote:
> Ryan,
>   The error(s) mean the linker can't find functions
> referenced in the code
> you are compiling.   Check the paths to the
> libraries inside your nmake.opt
> file (a less common cause of this problem is the use
> of out-dated
> libraries).
>   I've successfully compiled GDAL 1.2.1 with MrSID
> 4.x DSDK (Win2k, VC++6),
> but it will not work with RGB (i.e more than one
> band) MrSID images.  I
> think Andrey and others are fixing this.
> Brent Fraser
> ----- Original Message -----
> From: "Ryan Moore" <rmmoore80 at yahoo.com>
> To: <gdal-dev at xserve.flids.com>
> Sent: Thursday, August 05, 2004 7:26 AM
> Subject: [Gdal-dev] Problems compiling GDAL with
> MrSID 4.x DSDK
> > Sorry if this post got posted more than once, I'm
> new
> > to newsgroups.  I think I got it this time.
> > I am trying to compile GDAL with MrSID 4.0.9.713
> > support.  I have gdal setup in c:\gdal and mrsid
> setup
> > in c:\mrsid.  The nmake.opt file is set up to
> reflect
> > these changes and  the appropriate lines are
> > uncommented.  I run nmake /f makefile.vc and I get
> the
> > following error:
> > gdal12.dll:  fatal error LNK1120: 26 unresolved
> > externals
> > NMAKE: fatal error U1077: 'link' : return code
> '0x460'
> > Stop.
> > Above it is a TON of what appears to be the 26
> errors.
> >  Is it common to get this error?  Also, is there a
> > precompiled binary for GDAL 1.2.1 with MrSID
> 4.0.9.713
> > somewhere?  I couldn't find it on the downloads
> page.
> > Ryan M. Moore
> > __________________________________
> > Do you Yahoo!?
> > New and Improved Yahoo! Mail - Send 10MB messages!
> > http://promotions.yahoo.com/new_mail
> > Gdal-dev mailing list
> > Gdal-dev at xserve.flids.com
> > http://xserve.flids.com/mailman/listinfo/gdal-dev
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
