[Gdal-dev] Problems compiling GDAL with MrSID 4.x DSDK
Brent Fraser bfraser at geoanalytic.com
Thu Aug 5 10:22:10 EDT 2004
Ryan,
  The error(s) mean the linker can't find functions referenced in the code
you are compiling.   Check the paths to the libraries inside your nmake.opt
file (a less common cause of this problem is the use of out-dated
libraries).
  I've successfully compiled GDAL 1.2.1 with MrSID 4.x DSDK (Win2k, VC++6),
but it will not work with RGB (i.e more than one band) MrSID images.  I
think Andrey and others are fixing this.
Brent Fraser
----- Original Message -----
To: <gdal-dev at xserve.flids.com>
Sent: Thursday, August 05, 2004 7:26 AM
Subject: [Gdal-dev] Problems compiling GDAL with MrSID 4.x DSDK
> Sorry if this post got posted more than once, I'm new
> to newsgroups.  I think I got it this time.
> I am trying to compile GDAL with MrSID 4.0.9.713
> support.  I have gdal setup in c:\gdal and mrsid setup
> in c:\mrsid.  The nmake.opt file is set up to reflect
> these changes and  the appropriate lines are
> uncommented.  I run nmake /f makefile.vc and I get the
> following error:
> gdal12.dll:  fatal error LNK1120: 26 unresolved
> externals
> NMAKE: fatal error U1077: 'link' : return code '0x460'
> Stop.
> Above it is a TON of what appears to be the 26 errors.
>  Is it common to get this error?  Also, is there a
> precompiled binary for GDAL 1.2.1 with MrSID 4.0.9.713
> somewhere?  I couldn't find it on the downloads page.
> Ryan M. Moore
> __________________________________
> Do you Yahoo!?
> New and Improved Yahoo! Mail - Send 10MB messages!
> http://promotions.yahoo.com/new_mail
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
