[Gdal-dev] OGR: AVC driver issues (E00)
Tyler Mitchell tylermitchell at shaw.ca
Sat Aug 7 20:21:59 EDT 2004
> to update the "global" data set for GRASS I am trying to
> import an E00 file. After using 'avcimport' to create
> a binary coverage, OGR seems to have troubles (was working
> some month ago):
Worked for me.  Do we need to nail down versions?
tyler:/data2/map_data/global/carbon> avcimport olson-carbon.e00 olson-carbon
tyler:/data2/map_data/global/carbon> ogrinfo olson-carbon
Had to open data source read-only.
INFO: Open of `olson-carbon'
using driver `AVCBin' successful.
1: ARC (Line String)
2: CNT (Point)
3: LAB (Point)
4: PAL (Polygon)
tyler:/data2/map_data/global/carbon> ogrinfo olson-carbon ARC -summary
Layer name: ARC
Geometry: Line String
Feature Count: 15750
Extent: (-180.000000, -89.500000) - (179.999969, 90.499985)
Layer SRS WKT:
(unknown)
UserId: Integer (0.0)
FNODE#: Integer (0.0)
TNODE#: Integer (0.0)
LPOLY#: Integer (0.0)
RPOLY#: Integer (0.0)
On August 7, 2004 12:21 pm, Markus Neteler wrote:
> Dear list members,
> some month ago):
> ogrinfo -summary olson ARC
> INFO: Open of `olson'
> Layer name: ARC
> Extent: (-170128861896635013341904755760727851008.000000,
> -170140544564566716704068949377468596224.000000) - (0.000000, 0.000000)
> Layer SRS WKT:
> (unknown)
> The E00 file is here:
> http://cdiac.ornl.gov/ftp/ndp017/olson-carbon.e00.Z
> (1.2 MB)
> "Major World Ecosystem Complexes Ranked by
> Carbon in Live Vegetation" by Olson et al.
> Subsequently v.in.ogr doesn't import the file into GRASS 5.7.
> Thanks for any hints
>  Markus Neteler
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
