[Gdal-dev] Gdal_translate Error
David W. Lowther DLowther at scigis.com
Mon Aug 16 10:52:38 EDT 2004
Hi List,
We're processing some large SID images back to TIF to project. Some
images work just fine, others (most) have issues like this:
gdal_translate -projwin 635544.7539 3930207.3199 648110.83864
3915163.12478 h:\deqdata\oklahoma\Oklahoma.sid
h:\deqdata\oklahoma\x1_35097D4.tif -co "TFW=YES"
Input file size is 63929, 57190
Computed -srcwin 22976 35037 12566 15044 from projected window.
0.ERROR 1: Internalize failed
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset
The SID images draw correctly in ArcGIS and AV3.3.
The SDW files seem about right (compared to an adjacent image that runs
correctly).
Can someone help me understand what this means?
Thanks,
David Lowther
Senior Software Engineer
Strategic Consulting International
(405) 227-9051
dlowther at scigis.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040816/cb308230/attachment.html
