[Gdal-dev] Re: Assigning correct projection info to GEotiff extracted from MODIS 08 atmospheric HDF
William Hudspeth bhudspeth at edac.unm.edu
Mon Aug 16 12:32:36 EDT 2004
> William,
> It looks like you are using the old HDF driver. I'm recomment to try the
> new HDF code, available from the CVS. It should produce much better
> results for HDF-EOS Grid datasets.
> 						Andrey
Andrey, could you please direct me to the location of the CVS to which you
refer. I am having problems locating it.
Many thanks, Bill
