[Gdal-dev] gdal_translate & srcwin
Andrey Kiselev dron at ak4719.spb.edu
Mon Aug 16 15:46:44 EDT 2004
On Mon, Aug 16, 2004 at 02:14:23PM -0400, Charlton Purvis wrote:
> (I've mentioned attachments in this email, but I've put them in this
> dir instead of on this post.  They are here:
> http://nautilus.baruch.sc.edu/~cpurvis/gdal.)
> Just starting to dabble w/ GDAL, and I've probably got an obscenely
> naïve question for the group.
> gdalinfo HDF4_EOS:EOS_GRID:"dem30ARC_E60N0.hdf":demGRID:LandWater
> Corner Coordinates:
> Upper Left  (60000000.000,       0.000) (60000000d 0'214748364800.00"E,  0d 0'0.01"N)
> Lower Left  (60000000.000,-90000000.000) (60000000d 0'214748364800.00"E,90000000d 0'322122547200.00"S)
> Upper Right (180000000.000,       0.000) (180000000d 0'648540061696.00"E,  0d 0'0.01"N)
> Lower Right (180000000.000,-90000000.000) (180000000d 0'648540061696.00"E,90000000d 0'322122547200.00"S)
> Center      (120000000.000,-45000000.000) (120000000d 0'433791696896.00"E,45000000d 0'163208757248.00"S)
Hello, Charlton,
The driver works absolutely wrong for your image and I really want to
see that dataset. Could you place it somewhere so I be able to download
it?
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
