[Gdal-dev] assigning projection to geotiff extracted from MOD08 hdf
Andrey Kiselev dron at ak4719.spb.edu
Mon Aug 16 16:21:15 EDT 2004
On Mon, Aug 16, 2004 at 01:02:43PM -0600, Bill Hudspeth wrote:
> To begin with, I am trying to import MODIS08 atmospheric data files in
> HDF-EOS format with GDAL_TRANSLATE. According to the documentation
> and metadata associated with MODIS08 files, they are distributed as a
> 1-degree resolution grid (hence 360 by 180 pixels in dimension) in
> Lambert Azuthimal Equal Area projection (measured in degrees). Again,
> according to the metadata in the file (using gdalinfo), latitude
> values range from -90 to 90 degrees, and longitude values range from
> -180 to 180 degrees. No information is provided for dataum or
> ellipsoid.
> I have used GDAL_TRANSLATE to successfully extract a single band (1)
> from one of the subdatasets (472) in the HDF file using the following
> command:
> gdal_translate -of GTiff -b 1 -a_srs "+proj=laea +x_0=-180 +y_0=-90"
> HDF4_SDS:UNKNOWN:"MOD08_D3.A2002174.004.2003228005230.hdf":472 mod08test.tif
Bill,
You are using old HDF driver. Please, try the new one from the latest
snapshot and report any problems you will get.
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
