[Gdal-dev] GNUmakefile fix for OGR/GEOS
s duclos sylvain_duclos at yahoo.com
Tue Aug 17 21:42:55 EDT 2004
Here a simple fix to gdal/ogr/GNUmakefile
$ cvs -z3 diff -u GNUmakefile
Index: GNUmakefile
RCS file: /cvsroot/osrs/gdal/ogr/GNUmakefile,v
retrieving revision 1.69
diff -u -r1.69 GNUmakefile
--- GNUmakefile 30 Jul 2004 14:44:25 -0000      1.69
+++ GNUmakefile 18 Aug 2004 01:20:42 -0000
@@ -9,7 +9,7 @@
                ogr_featurestyle.h ogr_api.h
 ifeq ($(HAVE_GEOS),yes)
-CPPFLAGS       :=      -DHAVE_GEOS=1 $(GEOS_INC)
$(CPPFLAGS)
+CPPFLAGS       :=      -DHAVE_GEOS=1 -I$(GEOS_INC)
$(CPPFLAGS)
 endif
 CPPFLAGS       :=      -Iogrsf_frmts -I.
$(GDAL_INCLUDE) $(PROJ_INCLUDE) $(PROJ_FLAGS)
$(CPPFLAGS)
There is a "-I" missing before "$(GEOS_INC)".
Without that you'll a quite intuitive g++ msg:
"cannot specify -o with -c or -S and multiple
compilations"
The build choke later because of the new GEOS
interface
/bin/sh ../libtool --mode=compile g++ -Wall  -g
-DDEBUG  -Iogrsf_frmts -I. -I../port -I../gcore
-I../ogr -I../alg   -DHAVE_GEOS=1 -I/usr/local/include
-I../port   -c -o ogrgeometry.o ogrgeometry.cpp
 g++ -Wall -g -DDEBUG -Iogrsf_frmts -I. -I../port
-I../gcore -I../ogr -I../alg -DHAVE_GEOS=1
-I/usr/local/include -I../port -c ogrgeometry.cpp
-fPIC -DPIC -o .libs/ogrgeometry.o
ogrgeometry.cpp: In member function `virtual
geos::Geometry*
   OGRGeometry::exportToGEOS() const':
ogrgeometry.cpp:1249: error: no matching function for
call to `geos::WKTReader
   ::WKTReader()'
/usr/local/include/geos/io.h:111: error: candidates
are:
   geos::WKTReader::WKTReader(const geos::WKTReader&)
/usr/local/include/geos/io.h:123: error:
geos::GeometryFactory*)
make[1]: *** [ogrgeometry.o] Error 1
make[1]: Leaving directory
`/home/loup/dev/gis/gdal/ogr'
make: *** [ogr-target] Error 2
Also the #include "geos.h" is missing at the top of
this file
(ogrgeometry.cpp.)
Thanks,
Sylvain.
PS: GEOS interface was/is changing
(today CVS give a version of 2.0.0)
__________________________________
Do you Yahoo!?
Yahoo! Mail - 50x more storage than other providers!
http://promotions.yahoo.com/new_mail
