[Gdal-dev] gdal_translate question
Thu Aug 19 11:53:34 EDT 2004
David W. Lowther wrote:
> List,
> When running gdal_translate with the -proj_win option the program
> calculates a -src_win. I have been getting calculated src_win(s) with
> negative numbers (both for offset and size). Is this supposed to happen?
David,
If your projwin falls off the edge of the image this can happen.  I have
just patched gdal_translate to terminate if the window is off the image
since things cannot proceed properly.
Best regards,
