[Gdal-dev] Adding Fugawi .JPR Support to GDAL
Wed Aug 25 16:49:01 EDT 2004
Ed McNierney wrote:
> Christian -
> I presume you have found the JPR specification at http://www.fugawi.com/docs/jprdoc.pdf
> Unfortunately, the spec says that all of the fields are optional, which makes
 > it a little tricky to accurately identify the file.  You may wish to insist
 > that it have a filename ending in .jpr; otherwise I think you'd need to check
 > for all the possible keys and see if any are present.
Ed / Christian,
Ahh, I see.  So the .JPR file can contain the geotransform, GCPs and
SRS.  That will be a bit involved to return to the caller properly.
Best regards,
