[Gdal-dev] Adding Fugawi .JPR Support to GDAL
Christian Doenges christiandoenges at mac.com
Wed Aug 25 17:44:55 EDT 2004
On 25.08.2004, at 22:04, Frank Warmerdam wrote:
> int GDALReadWorldFileEx( const char *pszBaseFilename, double
> *padfGeoTransform,
>                          char ***ppapszMetadata, char *pszExtention,
> If ppapszMetadata is NULL then we don't even try to read the metadata.
Frank / Ed,
I _was_ going to modify the GDALDataset directly, but I see that this
is not such a good idea if it will break existing drivers. And you are,
of course, right about private code bases.
Metadata is my original fall-back solution, but there are a number of
issues with it (see below).
> Of course this does mean that each place where it is called must take
> care of
> integrating metadata from the .JPR file into the other dataset
> metadata but
> that might be a task worthy of driver by driver consideration anyways.
It's not an optimal solution, since I'll need to modify 5 drivers.
Maybe I can create a single function that will do the modifications for
all of the drivers? So the driver will do something similar to:
if (GDALReadWorldFileEx(....))
     GDALApplyMetataToDataset(this, papszMetadata);
Since the function will only need to work for BMP, TIFF, JPEG, GIF, and
PNG, it may be possible. I'll have to look into this.
> Ahh, I see.  So the .JPR file can contain the geotransform, GCPs and
> SRS.  That will be a bit involved to return to the caller properly.
Which is why I wanted to modify GDALDataset directly in the first
place. ;-)
I think it will be best to define a 'standard' set of metadata for
this. The projection could, for example, be turned into an OpenGIS WKT
or an EPSG identifier. It would make sense to include rules such as not
having GCPs if we have the geotransform matrix (and vice versa) so that
the .JPR parser can reduce the complexity of the data the driver will
have to deal with.
Having 'standard' metadata would also help with other formats that
allow, for example, specification of useable map boundaries or insets
into the map.
On 25.08.2004, at 22:27, Ed McNierney wrote:
> Unfortunately, the spec says that all of the fields are optional,
> which makes it a little tricky to accurately identify the file.  You
> may wish to insist that it have a filename ending in .jpr; otherwise I
> think you'd need to check for all the possible keys and see if any are
> present.
I don't know all the ESRI extensions to TFW, so I don't know if any
conflict with the Fugawi extensions. Is there a specification?
If I can rule out conflicts, I will simply loop through the lines and
match what I can. When I'm done, I will collect the data and cluster it
into metadata, as outlined above.
If I can't rule out conflicts, I will insist on .jpr.
Best regards,
Christian
Christian Dönges
Use GPS data on Mac OS X! <http://www.truenav.com/>
