[Gdal-dev] Problem with ogrtindex from OpenEV 1.7.4_FW (May 11, 2004)
Emil Zegers EZS at Syncera-ITSolutions.NL
Tue Aug 31 10:09:32 EDT 2004
Hello,
I have a problem using ogrtindex from OpenEV 1.7.4_FW (May 11, 2004).
When executing ogrtindex, it complains about not finding gdal11.dll in the path.
Strange because it should look for gdal12.dll?
As test I copied gdal12.dll to gdal11.dll.
Executing ogrtindex again now gives:
"Cannot find entrypoint from procedure ?getGeometryName at OGRLinearRing@@UAEPBDXZ in DLL file gdal11.dll."
Has anybody else encountered and/or solved this problem?
Best regards,
Emil Zegers
__________________
_____________________________
Per 1 september 2004 veranderen binnen onze holding drie werkmaatschappijen van naam en gaan twee bedrijfsonderdelen als zelfstandige werkmaatschappijen verder.
Syncera is de holding voor Syncera De Straat, Syncera IT Solutions, Syncera Water, Syncera Belgium, Syncera GeoData, Syncera Legal, Syncera Leisure, Syncera Realisatie, Groundwater Technology, ProKAM en LCHG (deelneming).
Meer informatie op: HTTP://WWW.Syncera.NL
