[Gdal-dev] Problem with ogrtindex from OpenEV 1.7.4_FW (May 11, 2004)
Tue Aug 31 11:40:26 EDT 2004
Emil Zegers wrote:
> Hello,
> I have a problem using ogrtindex from OpenEV 1.7.4_FW (May 11, 2004).
> When executing ogrtindex, it complains about not finding gdal11.dll in the path.
> Strange because it should look for gdal12.dll?
> As test I copied gdal12.dll to gdal11.dll.
> Executing ogrtindex again now gives:
> "Cannot find entrypoint from procedure ?getGeometryName at OGRLinearRing@@UAEPBDXZ in DLL file gdal11.dll."
> Has anybody else encountered and/or solved this problem?
Emil,
This was a mistake in how I was producing the OpenEV_FW releases.  This
executable wasn't updated for the last few releases.  Try the executable
at:
   http://home.gdal.org/~warmerdam/ogrtindex.exe
If that doesn't work I may need to prepare a new full OpenEV_FW release.
Best regards,
