[Gdal-dev] Windows compile of GDAL 1.2.1 with HDF
Brent Fraser bfraser at geoanalytic.com
Tue Aug 31 17:12:07 EDT 2004
Andrey,
I had a couple of spare hours so I built the makefiles and did some testing
(see attached zip of makefiles and modified source).  The makefile.vc in the
hdf4 dir needs to be "enhanced" to handle the new hdf-eos sub-dir, and a new
makefile.vc needs to be created for the new hdf-eos sub-dir.
I ran into a problem with the "sleep" function referenced in EHapi.c and had
to add a couple of windows include files (wrapped in a #ifdef WIN32 to
protect our Unix developers).
It compiled, so I ran a  couple of tests with gdalinfo.  It gave reasonable
output for MODIS and ASTER image data, but crashed on ASTER DEM data (the
same DEM data works in gdal 1.1.9).
Could someone run some ASTER DEM data through a Unix version of gdal 1.2.1
to see if the problem is Windows or gdal 1.2.1?
Thanks!
Brent Fraser
----- Original Message -----
To: "GDAL Dev" <gdal-dev at remotesensing.org>
Sent: Tuesday, August 31, 2004 1:27 PM
Subject: Re: [Gdal-dev] Windows compile of GDAL 1.2.1 with HDF
> Hi, Brent,
> On Mon, Aug 30, 2004 at 04:25:31PM -0600, Brent Fraser wrote:
> >   I'm trying to compile GDAL 1.2.1 with HDF on Windows.  I notice that
> >   with 1.2.1 there's a new sub-dir of fmts/hdf4/hdf-eos, but no
> >   makefile.vc.
> > Does anyone have a makefile.vc for that dir and one for the hdf dir?
> I have added the lost makefile (thiugh, not tested under Windows).
> Andrey
> Andrey V. Kiselev
> Home phone:  +7 812 5274898  ICQ# 26871517
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
Type: application/x-zip-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040831/34718d76/hdf.bin
