[Gdal-dev] New user needs helps
Frank Warmerdam fwarmerdam at gmail.com
Wed Dec 1 09:28:18 EST 2004
On Tue, 30 Nov 2004 22:27:56 -0000, Martin Hodder
<mhodder at highermappingsolutions.com> wrote:
> I hope someone can help me.
> I am trying to convert some points in Long / lat format to World Equidistant
> Cylindrical projection
> I have the following information on the projection:-
Martin,
The definition is in ESRI WKT format.  If you save it
to a text file called out.wkt you can do the following in
a translation to reproject input latlong points to this
coordinate system.
ogr2ogr  -s_srs WGS84 -t_srs ESRI::out.wkt  out_dir indatasource
Most comandline options for GDAL/OGR tools that accept a
coordinate system will allow you to give the name of a file
containing WKT.  And if you prefix the filename with ESRI::
the library will interprete the WKT as being ESRI WKT and
convert to "standard" format accordingly. The -s_srs switch
is assigning a source coordinate system to your input data
(in case it didn't have this properly defined already), and the
-t_srs is defining a target coordinate system to reproject
to.
Best regards,
