[Gdal-dev] Help creating NITF file.
Frank Warmerdam fwarmerdam at gmail.com
Wed Dec 1 16:58:32 EST 2004
On Wed, 1 Dec 2004 13:15:23 -0500 (EST), Ken Sewell <sewell at dramail.com> wrote:
> I'm trying to write out a NITF file and I need a little help.  This is
> the first time I've tried writing a file with GDAL so I'm in unfamiliar
> territory here.  I can write the file with all of the raster data, but
> I'm getting stuck on the georeferencing.  I know the lat/lon/alt of my
> images corner points but I'm not sure how to write that to the NITF file.
> Any help is appreciated.  Thanks.
Are you doing this with calls to the API or just using
gdal_translate?  Usually the easiest way to associate
georeferencing to a raw image is to write a world file for
it.  Many of the drivers, notably including the TIFF driver,
support world files.  Then you could just gdal_translate to
NITF, also setting the -a_srs WGS84 switch to let GDAL
know the coordinates are geodetic.
If you need details on how to prepare a world file let me know.
If you are using the API you should just be able to do
a SetGeoTransform() call.  The geotransform is essentially
the same values you would put in a world file though in a
different order.
Best regards,
