[Gdal-dev] Re: Help with gdal_merge errors
wlx wlx at mygis.org
Thu Dec 2 01:03:16 EST 2004
I have seen it when the output format doesn't support geographic
coordinate,so you can try use geotiff format.
> Hi GDAL Listers,
> I'm trying to use the gdal_merge distributed with the Windows
> binary of
> OpenEv_FW_182 to merge a large number of tiled JPEGs with
> this command line
> (most of the filenames were omitted for this example).
> C:\OpenEV_FW\python\python.exe
> C:\OpenEV_FW\pymod\gdal_merge.py -o
> Y:\isa03jpgm\camd_isa03_83m.jpg -of JPEG  -v 6876.jpg
> and I am getting this error message:
> 'import site' failed; use -v for traceback ERROR 6:
> GDALDriver::Create() ... no create method implemented for this format.
> Traceback (most recent call last):
>   File "C:\OpenEV_FW\pymod\gdal_merge.py", line 412, in ?
>     t_fh.SetGeoTransform( geotransform )
> AttributeError: 'NoneType' object has no attribute 'SetGeoTransform'
> Can someone offer a solution? I'm not well versed enough yet
> in Python to figure out (or fix) the error referenced on line 412.
> Also, I have PYTHONHOME and OPENEV_DIR env vars set, and
> added everything
> conceivable to my path, but could not get the gdal_merge.bat
> file to run.
> The error I get is "'python' is not recognized as an internal
> or external
> command, operable program or batch file." - so that's why I'm
> explictly calling the python exe and the gdal_merge script.
> There's got to be a better
> way, I just don't know what it is yet. Some advice there
> would also be appreciated.
> Thanks for the help,
> Julia Harrell
> NC DENR
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
