[Gdal-dev] missing io.h file?
Frank Warmerdam fwarmerdam at gmail.com
Thu Dec 2 12:12:49 EST 2004
On Thu, 02 Dec 2004 16:24:44 +0000, Norman Barker <normanb at comsine.co.uk> wrote:
> Hi,
> I had this error yesterday, just edit out the format as follows
> (from http://www.remotesensing.org/gdal/gdal_building.html)
> If you find build problems with one of the format drivers that you don't
> care about, just remove the format from the GDAL_FORMATS line at the
> bottom of gdal/GDALmake.opt, do a make clean, and make. This will drop
> it from the build and default runtime registration.
Folks,
I have dropped the ilwis support out of GDALmake.opt.in
for now.  I have contacted the author about other problems already,
and I will pass this issue on as well.
Best regards,
