[Gdal-dev] libgdal.la build error
Kirk R.Wythers kwythers at umn.edu
Fri Dec 3 10:28:44 EST 2004
I am getting a build error with 1.2.5 on Mac OSX. Does anyone recognize
this:
__TEXT,__text)
/usr/local/lib/libtiff.dylib(jidctint.o) definition of _jpeg_idct_islow
ld: warning multiple definitions of symbol _jpeg_fdct_float
/usr/local/lib/libjpeg.a(jfdctflt.o) definition of _jpeg_fdct_float in
section (__TEXT,__text)
/usr/local/lib/libtiff.dylib(jfdctflt.o) definition of _jpeg_fdct_float
ld: warning multiple definitions of symbol _jpeg_fdct_ifast
/usr/local/lib/libjpeg.a(jfdctfst.o) definition of _jpeg_fdct_ifast in
/usr/local/lib/libtiff.dylib(jfdctfst.o) definition of _jpeg_fdct_ifast
ld: warning multiple definitions of symbol _jpeg_fdct_islow
/usr/local/lib/libjpeg.a(jfdctint.o) definition of _jpeg_fdct_islow in
/usr/local/lib/libtiff.dylib(jfdctint.o) definition of _jpeg_fdct_islow
ld: Undefined symbols:
_fftw2d_create_plan referenced from libgrass expected to be defined in
/CLAM_EXTERNAL_LIBS/fftw/lib/libfftw.2.dylib
_fftwnd_destroy_plan referenced from libgrass expected to be defined in
_fftwnd_one referenced from libgrass expected to be defined in
/usr/bin/libtool: internal link edit command failed
make[1]: *** [libgdal.la] Error 1
make: *** [check-lib] Error 2
Thanks
Kirk R. Wythers
Dept. of Forest Resources
University of Minnesota
email: kwythers at umn.edu
tel: 612.625.2261
fax: 612.625.5212
