[Gdal-dev] JPEG2000
Chris Hodgson chodgson at refractions.net
Wed Dec 8 16:28:15 EST 2004
Have a look at the output of:
# gdalinfo --format JP2KAK
and cross-reference it against:
http://www.kakadusoftware.com/Usage_Examples.txt
I don't know about your motivation for converting - however, I found
that creating lossy files at about 1/10 the size of a GeoTiff were
visually identical. I used the following options to gdal_convert to get
this sort of output:
-co 'Clayers=20'
-co 'Clevels=8'
-co 'Corder=RPCL'
-co 'Cprecincts={256,256},{256,256},{128,128}'
-co 'ORGgen_plt=yes'
-co 'Creversible=no'
-co 'quality=10'
Note that decompression is very fast for a single user - however, I
tried to build a multi-user mapserver using jp2k files and it just
wasn't viable for me.
Good luck with it.
Chris
Jim LeMieux wrote:
> Hello I was trying to use OpenEV to convert a GeoTIFF to a JPEG2000
> (Kakadu version apparently) and It works using the Export utility,
> however the quality is degraded significantly and there are no options
> to set the compression. I tried the gdal_translate at the command line
> and got the same results (didn’t find any command line options to set
> compression). I’m looking to find a free compressor to compress all my
> GeoTIFFs to JPEG 2000 format at the lossless rate.
> Any suggestions?
> THANKS in advance.
> Jim LeMieux
> Kalispel Tribe
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at xserve.flids.com
>http://xserve.flids.com/mailman/listinfo/gdal-dev
