[Gdal-dev] Problems installing GDAL 1.2.5 - Crashes on Make
Frank Warmerdam fwarmerdam at gmail.com
Thu Dec 9 15:49:02 EST 2004
On Thu, 9 Dec 2004 20:07:02 +0000 (UTC), William Hudspeth
<bhudspeth at edac.unm.edu> wrote:
> Hello,
> gctp_wrap.c: In function `osr_inv':
> gctp_wrap.c:64: error: `OGRSpatialReferenceH' undeclared (first use in this
> function)
William,
I haven't run into a problem like this before, but the HDF support isn't
built in all that often.  One thing I notice is that gctp_wrap.c includes
ogr_srs_api.h using angle brackets instead of the double quotes used
elsewhere in GDAL.  Try changing:
#include <ogr_srs_api.h>
to
#include "ogr_srs_api.h"
in gdal/frmts/hdf4/hdf-eos/gctp_wrap.c and see if that helps.
Best regards,
