[Gdal-dev] undeclared identifier in netcdfdataset.cpp
Frank Warmerdam fwarmerdam at gmail.com
Fri Dec 10 13:24:46 EST 2004
On Fri, 10 Dec 2004 10:53:01 -0700, Jack Varga <jvarga at boulder.net> wrote:
>  Norman, (or anyone using netcdf prior to v. 3.5.1),
>  Would you mind doing me a small favor?  Since you're using an earlier
>  version of netcdf (3.5.0 and I'm using 3.5.1) and you compiled
>  ok (assumingly) would you mind grep-ing for one of these vars in the
>  netcdf includes to see if you get anything?  There are some noticeable
>  differences.  For example, my version of ncgen doesn't even have an
>  available '--help' options.
>  nc_inq_var
>  nc_inq_varndims
>  nc_get_vara_uchar
Jack,
I just downloaded and installed netcdf 3.5.1 on my Debian system
from source and nc_inq_var is defined in netcdf.h.  Is it possible to
are picking up some antique netcdf headers or something?
My GDAL build against the netcdf 3.5.1 library went without a hitch.
Best regards,
