[Gdal-dev] NITF ICHIPB Extension?
William Lyons wlyons at prologic-inc.com
Fri Dec 10 16:12:32 EST 2004
Frank,
>I would suggest you just derive corner GCPs and then use the
>GDALGCPsToGeoTransform() to compute the correct geotransform.
That's the path I found a few hours ago.  I'm still working on it
though.
Thanks again,
William Lyons
