[Gdal-dev] question on gdal_translate
francesco francesco.pirotti at unipd.it
Tue Dec 14 13:59:59 EST 2004
Hello,
is there a way to select a subdataset of an image which is in another
disk?  My partition has gdal stuff in D:\ and the image is in C:\
I cannot use gdal_translate using a subdataset such as:
HDF4_SDS:ASTER_L1B:"C:\image":10
It is ok if my image is in another folder in the same disk, then I can use
the ../ format to go backwords in the directory.  But no way to go in the
other disk.  Is there a trick?
Thank you
Francesco
