[Gdal-dev] Re: GDALDriver methods query
DaZoner bdezonia at wisc.edu
Fri Dec 17 16:38:25 EST 2004
Nevermind. I found the answer. Sorry for the noise.
"DaZoner" <bdezonia at wisc.edu> wrote in message
news:cpku19$r7q$1 at sea.gmane.org...
> I'm using the C-bindings to make calls to the GDAL dll I've built. I see
> that in C++ the GDALDriver has public attributes letting you determine
> that a driver implements methods (such as Create and CreateCopy). How
> could I determine this using th C-bindings?
