[Gdal-dev] Compile error on 1.2.5
Daniel Morissette dmorissette at dmsolutions.ca
Tue Dec 21 16:37:55 EST 2004
Kralidis,Tom [Burlington] wrote:
> # ogrinfo
> ogrinfo: error while loading shared libraries: libxerces-c.so.26: cannot
> open shared object file: No such file or directory
> Yet, this file is present:
> # ls -l /usr/local/lib/libxerces-c.so.26
> lrwxrwxrwx  1 root root 19 Dec 21 14:32 /usr/local/lib/libxerces-c.so.26
> -> libxerces-c.so.26.0
Is this a new version of libxerces-c.so.26 that you just installed? You
may need to run /sbin/ldconfig to update the runtime lib cache. (Also
make sure /usr/local/bin is in the /etc/ld.so.conf before you run it.)
  DM Solutions Group              http://www.dmsolutions.ca/
