[Gdal-dev] Compile error on 1.2.5
Daniel Morissette dmorissette at dmsolutions.ca
Tue Dec 21 17:07:47 EST 2004
Kralidis,Tom [Burlington] wrote:
> At any rate, it works now.  When I peruse /usr/local/lib, I find this
> hanging around:
> -rwxr-xr-x   1 root root 3486188 Jun 16  2004 libgdal.so.1.2.0*
> ...which is from gdal-1.2.0b.  Is it safe to blow this away?
Depends on whether you still have apps that were compiled with and need
this version to run. It doesn't hurt to leave it there if you're not
sure, except for the fact that it's one more (possibly unused) file in
your lib directory.
  DM Solutions Group              http://www.dmsolutions.ca/
