[Gdal-dev] Re: DODS/OPeNDAP driver updates
James Gallagher jgallagher at gso.uri.edu
Tue Feb 3 11:50:02 EST 2004
Paul,
MapServer uses GDAL to read rasters, so it'll be able to read rasters
from OPeNDAP servers by using GDAL. There's some configuration that must
be done for each OPeNDAP data source given the nature of virtually all
of those and the requirements of GIS applications, but it's documented.
I'm pretty sure that Dan is in touch with the MapServer folks to work
out the logistical details of getting a demo up and running.
Since this is less of a technical issue, we should probably spare the
GDAL list folks and take this off line (list?). :-)
James
On Tue, 2004-02-03 at 09:38, Paul Hemenway wrote:
> Hi, All,
> This is great news from James.  The question now is, how does it
> get incorporated into MapServer (is it already?  I'm completely
> ignorant), and then, how do we make the new capabilities available
> and let the user communities who might want to use it, know about it?
> Just trying to think ahead.
> paul
> > From jgallagher at gso.uri.edu Fri Jan 30 12:16:37 2004
> > Date: 30 Jan 2004 10:16:32 -0700
> > From: "James Gallagher" <jgallagher at gso.uri.edu>
> > To: "GDAL mailing list" <gdal-dev at remotesensing.org>
> > Cc: "Peter Cornillon" <pcornillon at gso.uri.edu>,
> >        "Paul Hemenway" <phemenway at gso.uri.edu>,
> >        "Daniel Holloway" <d.holloway at gso.uri.edu>,
> >        "Frank Warmerdam" <warmerdam at pobox.com>
> > Subject: DODS/OPeNDAP driver updates
> > Content-Type: text/plain
> > Mime-Version: 1.0
> > X-Mailer: Ximian Evolution 1.2.2 (1.2.2-5)
> > Content-Transfer-Encoding: 7bit
> > Hi,
> > I've checked in some changes to the DODS/OPeNDAP driver for raster data.
> > The driver now minimizes network use by transferring only the pixels
> > requested and by combining multiband requests into a single read from
> > the remote server when possible.
> > James
> > __________________________________________________________________________
> > James Gallagher		         The Distributed Oceanographic Data System
> > jgallagher at gso.uri.edu               http://unidata.ucar.edu/packages/dods
> > Voice/Fax: 406.723.8663
