[Gdal-dev] GDAL 1.19 with ECW problems
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Thu Feb 5 13:57:37 EST 2004
Hi everyone,
I've just downloaded the latest release of OpenEV from Sourceforge with
a view to seeing how well it can cope with ECW files. Unfortunately I
discovered that with the default Windows installation, no ECW support is
included, so I downloaded the ECW SDK along with GDAL 1.19 from
remotesensing.org and recompiled with ECW support under VS6 using the
instructions on www.remotesensing.org.
The installation process went something like this:
1) Point ECWDIR to C:\Program Files\Earth Resource Mapping\Image Web
Server\Client
2) Copy NCSECWc.dll from C:\Program Files\Earth Resource Mapping\ECW SDK
to the above directory (it appears to be a very old version but I don't
want to compress files yet anyway so this shouldn't matter).
3) Add the following lines near the top of ecwdataset.cpp:
CPL_C_START
void GDALRegister_ECW();
CPL_C_END
4) Compile GDAL installing into C:\gdalinst
5) Check gdalinfo --formats to make sure ECW is listed.
6) Make a copy of gdal11.dll as gdal119.dll
7) Add the following to INCLUDE_DIRS in setup.py - "C:\gdalinst\install"
8) From the OpenEV installation of Python launch the following:
	python setup.py install
8) Copy gdal11.dll to OpenEV\bin
9) Copy _gdal.pyd as _gdal.dll into OpenEV\pymod
After this fiddling (I've only ever used Python once before!) I managed
to install my new copy of GDAL in the OpenEV directory and I can now
load an ECW into OpenEV using File->Import and I've managed to export an
ECW as a JPEG. So far so good.
The part I'm now struggling with is trying to create a 3D view using two
ECW rasters - a standard and a DEM. Unfortunately the problem I'm
finding is that if I go to File->Open or File->Open 3D to load in the
ECW file then Python generates an exception and crashes :(. So I guess
what I'm looking for is: i) does this installation sound about right or
have I really messed up my OpenEV installation, ii) why is File->Open
different from File->Import and iii) how can a Python newbie go about
debugging a GDAL/Python application under Win32 to find out exactly what
the problem is?
Many thanks,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
