[Gdal-dev] GDAL 1.19 with ECW problems
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Thu Feb 5 17:21:08 EST 2004
> -----Original Message-----
> From: gdal-dev-admin at remotesensing.org
> [mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Frank Warmerdam
> Sent: 05 February 2004 21:41
> To: gdal-dev at remotesensing.org
> Subject: Re: [Gdal-dev] GDAL 1.19 with ECW problems
> Mark,
> Ahh, it looks like you built and installed an older GDAL
> (perhaps 1.1.9?) I would suggest you use the nightly snapshot
> of GDAL as the source to start from.  I presume that OpenEV
> is using a few new services from GDAL that didn't existing in 1.1.9.
Hi Frank,
Thanks very much! I just downloaded the CVS snapshot and recompiled and
it was exactly like you said - I could just drop the new DLL over the
existing one without any other effort required. And I can now Open maps
without any problems whatsoever :) You were right in that I downloaded
1.1.9 - I got the link from half way down
http://www.remotesensing.org/gdal/ where it indicates that this was the
latest source release?
Just to add that I think the GDAL/OGR looks absolutely fantastic as we
deal with GIS data in so many different formats this is exactly what we
need - I will wholeheartedly supply patches for any new formats we
experience in our travels :)
Many, many, many thanks!
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
