[Gdal-dev] python arrays - one step further
    Alessandro Amici
    alexamici at fastwebnet.it
    Fri Feb  6 09:10:12 EST 2004
folks,
the attached patch serie is meant to further optimize the gdal python layer.
up to now i only concentrated on raster read performance.
i had to extend a couple of intenal interfaces and (optionally) an external
interface, so i didn't apply the patches to cvs myself, and wait for Frank
approval. however the optimization applies to the current Numeric
implementation (no need of numarray) and it is fully backward compatible.
00_gdalreadraster-buffer.diff
py_GDALReadRaster accepts an additional optional argument that can be any
python object that offer a writable buffer (of the correct size) via the
buffer interface, i.e. an array object.
10_gdalnumeric-buf_obj.diff
BandReadRaster get advantage of the new GDALReadRaster argument.
with these two patches applied and no change to my test program and sample
dataset i obtained:
real    0m23.451s
user    0m17.861s
sys     0m4.667s
broken down as:
CPU: Athlon, speed 1000.15 MHz (estimated)
vma      samples  %           app name                 symbol name
001323c0 15428    33.2221     libgdal.so.1.1.9         GDALCopyWords
00077370 13146    28.3081     libc-2.3.2.so            memset
c01b2450 4346      9.3585     vmlinux                  __copy_to_user_ll
00077990 2713      5.8421     libc-2.3.2.so            memcpy
c01b1f30 2557      5.5061     vmlinux                  fast_clear_page
001322e0 1746      3.7598     libgdal.so.1.1.9         GDALSwapWords
remember that we went from 36.5s to 28.5s removing a unneeded memcpy. this
further speed up to 23.5s is apparently due to the fact that clearing the
memory (inside zeros()) is faster that copying it over (inside fromstring()).
but it is not finished, fasten your seat belts!
20_gdal-band-buf_obj.diff
Band.ReadAsArray() accepts an additional optional argument where the result is
stored (much like the output argument of the ufuncions).
in order to take advantage of the output argument you need to adapt your
applications, but if you need to read the image in chunks and you allocate a
reusable buffer array, this is where you can get:
real    0m14.506s
user    0m11.597s
sys     0m2.617s
and:
001323c0 14990    51.6362     libgdal.so.1.1.9         GDALCopyWords
c01b2450 4419     15.2222     vmlinux                  __copy_to_user_ll
00077990 2796      9.6314     libc-2.3.2.so            memcpy
001322e0 1714      5.9042     libgdal.so.1.1.9         GDALSwapWords
00077370 1198      4.1268     libc-2.3.2.so            memset
note that the memcpy is not due to python but it is called inside
GDAL_CopyWords, and the only further overhead due to Numeric is the (not
really useful) memset. with numarray we could avoid that and a couple of code
contorions, oh well.
anybody interested, please test, but...
a word of warning: this is my first time playing with python modules internal!
Frank, something like that needs to go in, do you have any comment?
cheers,
alessandro
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040206/75d31057/00_gdalreadraster-buffer.bin
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040206/75d31057/10_gdalnumeric-buf_obj.bin
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040206/75d31057/20_gdal-band-buf_obj.bin
