[Gdal-dev] Using OGR Python to analyse stream layers
Christopher Fonnesbeck chris at fonnesbeck.org
Mon Feb 9 10:01:34 EST 2004
On Feb 9, 2004, at 9:44 AM, Frank Warmerdam wrote:
> The OGR Python interface would be fine for accessing stream vectors in
> any
> OGR supported format (which does not include GRASS at this time).
> However,
> OGR has no mechanism for finding the nearest feature to a point, or for
> computing the distance betweena feature and a point.  So you would end
> up
> having to do this yourself in python which could be kind of
> computationally
> expensive.
Thanks for the advice! What if I had a polygon coverage with affected
polygons instead; could those then be intersected with a stream
coverage, or is that outside of OGR's realm?
Is there documentation/examples of how OGR handles line features like
stream networks?
> One slightly exotic solution to your problem might be to keep your
> network
> data in PostGIS and then use the PostGIS primitives (based on GEOS) to
> find
> the nearest geometry.  You could use access postgis via OGR's PostGIS
> driver
> or do the operations directly from Python using ODBC and then use a
> python
> package to parse the results from PostGIS.  You can request results in
> WKT
> for instance.  You could use OGR to parse the WKT geometry but there
> is also
> another "pure python" module available now that understands OGC
> geometry
> formats that might be even simpler.
I presently use MySQL for all my GIS databasing, and version 4 now
supports storage of spatial features. Is there a mysql driver for OGR?
Thanks again,
Chris
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
