[Gdal-dev] problem with new pyton-gdal
Fulko van Westrenen Fulko.vanWestrenen at dto.tudelft.nl
Tue Feb 10 12:05:11 EST 2004
On Tue, Feb 10, 2004 at 11:49:00AM -0500, Frank Warmerdam wrote:
> In any event, you can likely get things working by setting the GDAL_DATA
> environment variable to point to the directory with the .csv files in it.
> When they aren't found the S-57 driver just makes layers from the object
> based on their geometry class instead of by object class.
Hello Frank (and all the others),
Setting GDAL_DATA to /usr/share/gdal worked!
Thanks,
Fulko
Fulko van Westrenen
Fulko.vanWestrenen at DTO.TUDelft.NL
