[Gdal-dev] missing libproj.so
Matt Wilkie matt.wilkie at gov.yk.ca
Wed Feb 11 16:38:59 EST 2004
Frank Warmerdam wrote:
> By default GDAL is built to try and dynamically load libproj.so at
> runtime. The good part of this is that you don't need to have libproj
> around to build GDAL, but if you later install it - bam - GDAL's
> projection support starts working too.
> You can try building and installing PROJ now and see if things work,
> but this stuff may be fragile on Cygwin.
I have, but libproj.so is not created or installed, only libproj.a and
libproj.la. I note that shared libraries are supposed to be built by
default according to ./configure --help. I'm at the limit of knowledge
here but am happy to keep trying out the various options until something
works.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
