[Gdal-dev] Updated MrSID Driver
Johan A. Goossens goossens at act.nato.int
Fri Feb 13 15:06:00 EST 2004
Andrew,
I did my work last weekend before you posted the new version to CVS. I
downloaded the latest last night, compiled it against the MrSID 3.2.1 DSDK
with VC-7 on a Windows XP platform. It seems to work just fine on the MrSID
images I have. Thank for the great work. I just wish I had waited a week
:-). I could have been at that party at least an hour earlier.
Regards,
Johan Goossens
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Andrey Kiselev
Sent: Wednesday, February 11, 2004 5:00 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Updated MrSID Driver
On Tue, Feb 10, 2004 at 08:31:46AM -0500, Johan A. Goossens wrote:
> Attached are an updated version of the MrSID driver and VC-7 Makefile.
> They have been changed to be compatible with the new 3.2.1 MrSID DSDK.
> I've tested it on a Windows XP platform and successfully used gdalwarp
> on a number of MrSID files.
> You also need to change nmake.opt and configure since the libraries
> are now in ${MRSID_DSDK}/lib (not in $MRSID_ DSDK}/bin/lib).
Johan,
Have you tried the latest driver update? I did changes needed to be
compatible both with new and old API versions.
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
