[Gdal-dev] ogr virtual data issues with connecting to excel
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Mon Feb 16 09:23:45 EST 2004
> -----Original Message-----
> From: Normand Savard [mailto:nsavard at dmsolutions.ca]
> Sent: Monday, February 16, 2004 9:13 AM
> To: gdal-dev at remotesensing.org
> Subject: Re: [Gdal-dev] ogr virtual data issues with
> connecting to excel
> Tom,
> You could verify your connection with the Excel driver by using this
> small application:  ODBCView:
> http://asia.cnet.com/downloads/pc/swinfo/0,39000587,39034753s,00.htm
Thanks for the info.  Frank is currently debugging.
> Norm
> Kralidis,Tom [Burlington] wrote:
> >Hi,
> >I'm trying to connect to an excel document using this
> approach, but am
> >having problems doing so.
> >I have created a system DSN
> >Here is my .ovf file:
> ><OGRVRTDataSource>
> >	<OGRVRTLayer name="plantwatch">
> <SrcDataSource>ODBC:plantwatch2,plantwatch</SrcDataSource>
> >		<SrcLayer>plantwatch</SrcLayer>
> >		<GeometryType>wkbPoint</GeometryType>
> >		<LayerSRS>WGS84</LayerSRS>
> >		<GeometryField encoding="PointFromColumns"
> x="longitude"
> >y="latitude"/>
> >	</OGRVRTLayer>
> ></OGRVRTDataSource>
> >When I test with ogrinfo, I get:
> >C:\ms4w\Apache\cgi-bin\ms_odbc>.\ogrinfo.exe
> >\ms4w\mapserv\services\naturewatch\plantwatch2.ovf
> >ERROR 4: Update access not supported for VRT datasources. ERROR 1:
> >Unable to identify source X or Y field for PointFromColumns encoding.
> >FAILURE:
> >Any suggestions?  The x and y attributes exist as columns in
> my excel
> >file. As a workaround, when I converted the excel file to an access
> >database, it worked.
> >I can post the excel document on request.
> >Thanks
> >..Tom
> >Tom Kralidis
> >Systems Scientist
> >Environment Canada
> >Tel: +01-905-336-4409
> >http://www.ec.gc.ca/cise/
> >_______________________________________________
> >Gdal-dev mailing list
> >Gdal-dev at remotesensing.org
> >http://remotesensing.org/mailman/listinfo/gdal-dev
> http://remotesensing.org/mailman/listinfo/gdal> -dev
