[Gdal-dev] Problems building gdal dll with libtool on MinGW
Mario Beauchamp starged at videotron.ca
Wed Feb 18 01:33:32 EST 2004
Hi Alessandro,
I was hoping you would jump in since I knew you were one of the few on the list familiar with MinGW
On Tue, 17 Feb 2004 08:22:39 +0100, Alessandro Amici <alexamici at fastwebnet.it> wrote:
>all mingw installation i tried had only static libraries inside /usr/lib
Same here except they are in /lib... I guess we could make dlls if we wanted using the a2dll script.
>you may possibly get the gdal internal copy of libz using
>"--with-libz=internal", but you need to find a way to get a shared copy of
>libm. you should probably ask to the mingw list.
As you may have read in my other post, I finally chose to build GDAL as a static lib and inside the
Dev-Cpp environment (ie no MSYS) and everything is fine now, althought it took a whole day of
fiddling to fine tune the Dev-Cpp project file...
Thanks for your support.
Mario B.
My Landsat images:
http://pages.infinit.net/starged/landsat/home.html
