[Gdal-dev] Problems building gdal dll with libtool on MinGW
Alessandro Amici alexamici at fastwebnet.it
Wed Feb 18 03:45:47 EST 2004
Thom,
On Tuesday 17 February 2004 17:14, Thom DeCarlo wrote:
> The place where I experience problems with static libraries is when I try
> to include the Earth Resources Mapping ECW library. It is only available as
> a static library and that causes problems when I build the gdal plugin for
> OpenSceneGraph. Has anyone solved this?
not to my knowledge, and i've never used the ecw library. could you post a
more datailed bug report? (platform, configuration command, error message
etc)
i can try to figure that out.
cheers,
alessandro
