[Gdal-dev] 1.2.0a Release
Andrey Kiselev dron at ak4719.spb.edu
Sat Feb 21 09:45:48 EST 2004
On Sat, Feb 21, 2004 at 08:10:48AM -0500, Norman Vine wrote:
> GDAL build failed when attempting to build static proj4 link and
> libtool
> The problem appears to go away if -lproj is added to the $LIBS in
> GDALmake.opt.in if $PROJ_STATIC is defined
I have added more logic to --with-static-proj4 switch. Now it can take
values "yes", "no" and "/path/to/binary/installation". There should be
no problem in case of --with-static-proj4=yes and system wide
installation. Please, test.
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
