[Gdal-dev] 1.2.0a Release
Sat Feb 21 10:46:11 EST 2004
Norman Vine wrote:
> It would also be nice if there was a configure mechanism in gdal
> and proj to hardwire the location of the 'shared' data in order to
> facilitate remote installation on a machine on which one did not
> have enough privilige to run as 'su'
Norman,
Have you tried the --datadir option for the PROJ.4 configure?  I am not
sure if it works, but I think it might.  I have created a 1.2.0 release
blocking bug to make the --datadir option work with the GDAL configure.
   http://bugzilla.remotesensing.org/show_bug.cgi?id=501
Note, that you can just edit GDALmake.opt and change INST_DATA before
starting your build.  But I realize many people seem to want to do everything
from the configure commandline.
Best regards,
