[Gdal-dev] 1.2.0a release
Gillian Walter gillian.walter at atlantis-scientific.com
Tue Feb 24 14:33:59 EST 2004
I just tried compiling gdal 1.2.0a on the Irix 6.5 platform, and got the
following error near the end:
/usr/bin/ld -n32 -r -o .libs/libgdal.la-2.o
./ogr/ogrsf_frmts/o/.libs/ogravcbindatasource.o
./ogr/ogrsf_frmts/o/.libs/ogravcbindriver.o
(massive list of object files)
/.libs/ograssemblepolygon.o ./ogr/.libs/ogr2gmlgeometry.o
./ogr/.libs/gml2ogrgeometry.o  .libs/libgdal.la-1.o
ld32: FATAL   11 : Object file format error (.libs/libgdal.la-1.o): bad
sh_link field in relocation section.
gmake[1]: *** [libgdal.la] Error 4
gmake[1]: Leaving directory `/data/esa2/temp_gwalter/local_builds/gdal'
gmake: *** [check-lib] Error 2
I used ./configure --without-gif --without-bsb --without-jpeg
--with-libz=internal --with-png=internal --with-libtiff=internal
--with-geotiff=internal
I also used these configuration options on the fedora linux platform
(gdal compiled without error) and on SunOS 5.8 (gdal initially failed to
compile, but succeeded after I manually added -D_REENTRANT to C_OPTFLAGS
and CXX_OPTFLAGS in GDALmake.opt).
I'll be trying to build it on windows sometime in the next few days
(microsoft visual c++ 6.0).
Gillian
